[Urgent for Project] Sony Vegas 16 Crashing Problems:
Hi there,
Recently got a new CPU, MOBO, and RAM. Upgraded from Windows 7 to Windows 10.
In the past few days since the new pieces, my Vegas 16 has been fine - no problems. While editing a larger project today, towards the end it just started crashing.
Crashes with very basic things, like 1-2 minutes of cutting, undoing things etc.
Any idea what is happening and why this has suddenly started even though for the past few days it has been fine?
Really problematic. I have an urgent project due in a few hours.
Error:
amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a\MSVCR90.dll
Problem Description:
  Application Name:    VEGAS Pro
  Application Version: Version 16.0 (Build 248)
  Problem:             Unmanaged Exception (0xc0000005)
  Fault Module:        C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a\MSVCR90.dll
  Fault Address:       0x0000000073A5E293
  Fault Offset:        0x000000000001E293
Any help would be greatly appreciated. This is an urgent project for a large YouTuber - the video will be seen by 1m+ people. Please help them too!
Best,
Everything I could find on that error points to it being a graphics card driver issue and not anything to do with your new CPU/Mobo/RAM. When was the last time you updated your drivers for your GPU? I'd download the latest drivers, uninstall the old ones with DDU (Display Driver Uninstaller) and then install the new drivers and try it again.
Thank you for the feedback, will give it a shot shortly.
Let me know if it works or not, I always like to know if I've been helpful xD
Will do - I am actually asking on behalf of someone else who will try fix it a bit later today. We didn't want to risk it in the end so had to finish the video until 3am while it was still crashing ahha
Yes, it helped - tried a few other things too so not exactly sure what fixed it. But good suggestion and it helped :)
