Hello guys, what do you think about a pc that has no case? I mean it has but its not covered like the Thermaltake core p5, is it bad for every day use? Can the dust easily build up in the components? Thermals are bad? Thanks for the replies in advance
Gaming pc: CPU(AMD Ryzen 5 1600), MOBO(MSI B450M Bazooka), RAM(DDR4 2x8GB 2666MHz Kingston Fury Black), STORAGE(120GB WD Green SSD , 1TB WD Blue HDD), GPU(incoming), PSU(incoming), CASE(Nzxt h400i)
https://linustechtips.com/topic/976969-open-air-or-case/
If you mean a test-bench, then it's good for everyday use if you don't mind the hazards of things falling on it
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/976969-open-air-or-case/#findComment-11799244
Not like a test-bench, like for everyday use, I want to mount it on the wall
https://linustechtips.com/topic/976969-open-air-or-case/#findComment-11799248
Thermals will be great, as for dust buildup it really depends on the environment; every house is different.
https://linustechtips.com/topic/976969-open-air-or-case/#findComment-11799284
It will be fine but depending on your environment, if you live in a dusty place (desert for example) then yes it will get dusty very easily. But as long as nothing else will touch it (people, animals, something falling on it or hitting it like a kid's thrown toy) then it should be okay. I'd still recommend an enclosure or something like the Core P5 just to have something blocking "DIRECT ATTACKS" against your battle station.
https://linustechtips.com/topic/976969-open-air-or-case/#findComment-11799383
