Need help Troubleshooting GPU issue.
Go to solution Solved by Tristerin,
3 minutes ago, Cwis said:
I built this computer in December of 2015 and got windows around February of 2016. The Graphics card is not very old. I bought the Asus R9 380 STRIX 2gb the same time i built the computer. the reason I meant that i do not have access for logging into my computer. This happened around early to Mid summer.
So its likely : Green Screen of Death (your GPU is borked)
or
Dust/Heat issue - those cards tend to run extremely hot.  And extreme heat over time regardless of it supposedly taking those temps still dries out the thermal paste (if the card isn't borked).  My only thought, and I am no expert just a shade-tree PC guy, is that if your GPU isn't borked, you need to pull it out, check the slot for dust, clean the card free of dust, and replace the thermal paste on the card and try from there.
It may work.  I thought I had killed one of my GPU's the other night and by reseating it (everything about the issues it was giving was saying it was dead with the slight chance of reseating it could fix it, and it did) - good luck!  Or someone smarter than me may chime in.
Hey my name is Chris, and i have been having some problems with my computer for the past 4 months. My computer can’t even start up without blue screening, and when it does eventually start loading and updating Windows, my screen turns completely green after it finishes. I have been able to test and confirm that this is a graphical issue, but i don’t know how to fix it. I have reset my computer completely, gotten a new SSD and loaded Windows 10 onto there and even considered buying a new CPU just to rule it out as a problem. But considering the only video output ports i have are on my graphics card, I’ve come to the conclusion that I either need to fix my graphics card, or get a new one. Any advice? Remember, i have 0 access to my computer.
https://linustechtips.com/topic/976718-need-help-troubleshooting-gpu-issue/
or
Potentially a dust/heat issue (how old of a GPU?)
Why don't you have access to the PC?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
What specs do you have?
Trial and error is going to be your best friend here-
If you have integrated graphics, try and use that instead
Try moving ram around
try a different graphics card if you can
reseat the graphics card
reset cmos (by taking out your motherboard battery and placing it back in)
Those are probably good starting places
or
Specs
AMD FX6300 w/ Stock cooler.
MSI 980FXA Gaming motherboard
Asus STRIX R9 380 2Gb
16GB DDR3 Crucial Ballistix Ram
Samsung EVO 128gb
Western Digital Blue 1TB
Corsair CX750M semi modular PSU
and 6 fans of different Colors
I do not have integrated graphics, if i did i would have solved this issue already.
I used a different graphics card slot, but i have not moved the ram around. I wish i had access to a separate graphics card that i could use until i fix my current one, and i have not tried to take out my motherboard battery.
or
or
Thank you, i will try to clean up my card and get back to you.
