4 hours ago, RRhyno said:
So I’m a beginner to building computers, but I want to build one. I need a gaming computer because my current one can’t run Fortnite and my Xbox broke. The problem is I have a $600 price range. I just need to be pointed in the right direction of cheap parts.
thanks all
Build something like this.......
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($69.99 @ Newegg Business)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($74.99 @ Newegg Business)
Storage: Patriot - Burst 240GB 2.5" Solid State Drive  ($36.99 @ Newegg)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: PowerColor - Radeon RX 570 4GB RED DRAGON Video Card  ($164.98 @ Newegg)
Case: DIYPC - DIY-F2-P MicroATX Mini Tower Case  ($25.97 @ Newegg Business)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($28.98 @ Newegg)
Total: $591.88
Generated by PCPartPicker 2018-09-26 03:02 EDT-0400
https://linustechtips.com/topic/976141-so-i-need-help/page/2/#findComment-11792190
3 hours ago, dgsddfgdfhgs said:
Probably better off with a cheaper RX 570 and 16GBs of RAM
https://linustechtips.com/topic/976141-so-i-need-help/page/2/#findComment-11792247
2 minutes ago, dgsddfgdfhgs said:
true for now, but it will be a nightmare for future upgrades.
its much easier to another 2x4gb rams than replacing and get rid of "old" GPU
You're unlikely to ever need to replace 16GBs of RAM for the foreseeable future
You're likely to replace an RX 570 or 580 within 2 years.
Was recommending the cheap APU machine as Ryzen 3000 CPUs come out next year for a likely sizable jump over 2000 series CPUs, and there might be a 12nm polaris refresh coming soon
https://linustechtips.com/topic/976141-so-i-need-help/page/2/#findComment-11792264
