Hello
today my GF's pc shut down this morning and wouldn't turn on at all
so i tried to remove the gpu from the system and the system runs fine but if i plug the psu power to GPU again it wont turn on it runs on a 550W psu and has been running like that for months now.
i tried to put the gpu in my pc and my pc wont turn on aswell if i put the GPU in it?
and when i try to start the pc after just plug in the power to pc  the fans on pc spins a a split second
the GPU is an MSi gtx 970 oc version - never been overcloaked by me
mobo - ASUS PRIME A320M-K
psu Corsair VS 550W
8gb hyperx ram 2400
would appreciate any input if theres way to fix this or any of you know what could cause any of this issue or if only option is to get new gpu.
when it happend was under not heavy load just playing a game with 3 fans open in browser
thanks in advance
https://linustechtips.com/topic/975794-pc-wont-turn-on-gpu-issues/
VS = Very Shit. Shouldn't be used for anything but an older secondary system with a blown PSU.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
