11 minutes ago, Kim99 said:
I just had my MSI Motherboard (B350 Gaming Plus). And I was wondering which port on the motherboard should my LED fan (AMD Wraith Spire LED) cable go?
I assumed it should go to the “ amd led fan “ port, but I can’t find that port on my motherboard.
Welcome to the Forums!
You would need to connect it to the 4pin RGB header on the motherboard, note the orientation.
There will be one set of pins for your fan and then another for the RGB header on that board. I believe the RGB Header is near the bottom left. Check your manual
