Help with resolution!
Umm... Can you try to explain in other words? Are you trying to strech some windows across 2 monitors with different resolution? Is that software windowed or fullscreen? Or are you having two monitors with same resolution and another keeps losing set resolution?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/975624-help-with-resolution/#findComment-11790058
When i strech my main monitor and click on other monitor on main monitor it refreshes resolution
https://linustechtips.com/topic/975624-help-with-resolution/#findComment-11798756
