Help in storage upgrade for hdd
naokuronao
Hello, I'm right now almost at my limit capacity for my seagate 3tb hard drive and I'm thinking of upgrading my hard drive. I'm also noticing a lot of failure where some of my data is starting to be missing so its a bit of urgent situation.
I'm thinking of buying an 8tb hard drive since I'm quite the data hoarder but I store a lot of data for video editing purposes. I did a bit of research and saw HGST has the most reliable hard drive but I also heard its pretty noisy apparently. The one I am referring to is the HGST deskstar hard drives. I also saw WD black and the Seagate barracuda pro hard drives but sadly in my area they do not have the bigger capacity available at the moment.
Would the HGST harddrive drive be okay to use inside a desktop pc? Otherwise can you recommend me an hard drive. Thank you!
Get a WD red or gold if you want better reliability.
They are quieter than black too.
