I agree with @GoldenLag, the b450 tomahawk is a great mobo and ocing the 2600 makes it just as good as the 2600x for $55 cheaper, and with the extra money you could just get a $30 cpu cooler if you plan on ocing. Also, the dual cards aren't that great, the XFX Radeon RX 580 8GB https://www.amazon.com/dp/B06Y66K3XD/?tag=pcpapi-20
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/974784-first-pc-build-2018/#findComment-11779638
9 hours ago, Raccoon202 said:
Hi I'd like to build a humble 1080p60 high-ultra  gaming rig is this good?
https://pcpartpicker.com/list/k9fCMZ
I'd like to play all kinds of games (I am aware the rx580 is pretty old but it can do 1080p60 and I might move to navi in a year or two).
$1000 budget, eh?
https://pcpartpicker.com/list/QxRbV6
https://linustechtips.com/topic/974784-first-pc-build-2018/#findComment-11781093
