Hi guys,
I'm thinking about buying a gaming laptop for Machine Learning projects so I want to get something powerful. I was wondering. I hear that the NVidia Volta range is coming out for Desktops. How long do you think it will be before they're available for use in Laptops?
I also wondered. Is the 2080 the same as the Volta or are they different things?
https://linustechtips.com/topic/974344-nvidia-volta-noob-help/
The 2080 uses Turing, not Volta. Volta is only available on a select few Quadros, Teslas and the Titan V.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/974344-nvidia-volta-noob-help/#findComment-11776031
19 minutes ago, KiranR said:
Hi guys,
there are some differences between turing and volta, but they both have deep learning cores. if you want something really powerfull get yourself a good laptop with thunderbolt and an external gpu
https://linustechtips.com/topic/974344-nvidia-volta-noob-help/#findComment-11776072
