Running through 2 rads?
Solved by Dissitesuxba11s,
It's a thing. Also, loop order doesn't matter.
Also,
QuoteQ: Loop order
A: People often wonder if loop order is important in the design and layout. Not really is the simple answer. A water cooling loop is exactly that, a closed loop. Water is being pushed and pulled and once your system is up and running, the temperature difference at any one point may be only a degree or two. The only general recommendation is to mount things so the reservoir outlet feeds the inlet of the pump. This prevents the pump from running dry and also helps to collect air during the priming and stop it from being recirculated (just ensure the outlet is mounted higher the the pump inlet).
