I would do 4.5 at about 1.2 volts, and creep your way up from there. You should be able to work your way up to 4.7 at 1.3 volts or less. Test with Aida64
Primary PC:
PSU tier list
How many watts do I need?
17 minutes ago, Ziomek64 said:
Core clock and Vcore are only things i need?
Yeah if you're only gonna do a simple overclock
Primary PC:
PSU tier list
24 minutes ago, Ziomek64 said:
I would like to overclock my 8700k to 4.7. My motherboard is ASrock Z370 Extreme4 , Cooler is Dark Rock Pro 4. Where should i start? I know it's small overclock but don't want to fuck this up.
4.5 at 1.2V is waay too high.. you can easily do 4.6Ghz at 1.15V on theoretically every 8700K, and 4.7 is usually in the 1.2 - 1.25 range depending on the quality of the silicon, some even can do 4.7 at lower than 1.2V, but the average is around 1.2-1.25 :) doesn't get worse than that.
make sure to pay attention to your voltages in HWinfo or any other program, the voltage you set in the BIOS isn't always the voltage that your CPU gets, you need to know what you're doing to get it overclocked correctly.
Quote or Tag people so they know that you've replied.
1 minute ago, syn2112 said:
waay to high
Hardly. In case OP is a silicon lottery loser, the little bump in voltage is needed, and then he can work his way down from there
Primary PC:
PSU tier list
2 minutes ago, Ziomek64 said:
Is there a chance of CPU not working if something fucks up at 1.25?
start with 4.7 1.3, and lower the voltage from there, the cpu won't fry on anything under 1.4
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
1.25 won't damage your CPU, and the dark rock pro 4 will keep things nice and cool
Primary PC:
PSU tier list
My i7 8700k hits 4.8 ghz on all cores at 1.24
Minecraft plugin developer
Desktop:
CPU= I5 12400F
RAM = 2x 32gb DDR4 3200MHZ Corsair Vengeance LPX
Motherboard = MSI Z690-A-PRO Wifi DDR4
GPU= RTX 3050
SSD = Samsung 980 Pro 1TB
PSU= Corsair RM750
Laptop:
CPU= AMD Ryzen 5 5500u
RAM= 1X 4gb (soldered 3200mhz), 1x 16gb ddr4 3200mhz (so-dimm)
SSD= Samsung 970 Evo 1TB
