i want to upgrade my home network, currently i use cheap switches that crash from time to time, so i want to replace them.
i need 2 things. a bunch of ports, and gigabit.
i don't want to pay to much for it, and i'm familiar with used hardware so if it's an older model that's fine.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/973603-network-switch-recommendation/
How many ports do you need? What's your budget?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
about 15 to 20.
budget max €100
She/Her
14 minutes ago, firelighter487 said:
about 15 to 20.
budget max €100
Aight. Word of warning, when you're going with higher end equipment, you'll get actively cooled switches, so I wouldn't keep them in the same room you sleep in.
Generally, I go for Netgear switches if possible. They've always been stellar to me, and some models have lifetime warranties, such as the Prosafe GS724T.
One happens to be for sale for €100 right now.
https://tweakers.net/aanbod/1764583/netgear-prosafe-gs724tv3.html
the room they will be in already has a server in it too so...
She/Her
Most unmanaged ones are pretty synonymous, usually it's just picking the quantity of ports and the style you want, or other features like rackmount if you need that.
If you had any feature interest like VLANs I'd at least start looking at the smart side.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
