Hello all!
Today I recovered an HDD from an old decoder (mostly just to try it out). After some fooling around with is I maneged to get it working. But now I see in disk maneger that it is "simple volume" and not "primairy partition".
I did some looking around but can't seem to find what it means and if it mathers.
Anyone that can help me?
Thanks in advance!
Greets from a young guy that is learing everyday!
https://linustechtips.com/topic/973386-primary-partition-and-simple-volume/
Hello 42thgamer,
Change simple volume to primary by converting dynamic disk to basic, use the following DISKPART commands:
Step 1 :- Open CMD and type diskpart to open the diskpart console.
Step 2 :-  Then list disk and press enter.
Step 3 :- Type select disk 1 (Or the right corresponding number) and press enter.
Step 4:- Type delete volume 0 and press enter. This command is used to delete the volume.
Step 5:- Repeat steps 3 and 4 for each volume  listed. In this ways delete all the volume which are in the list.
Step 6 :- after done step 5 then type select disk 1 and hit enter.
Step 7 :- type convert basic
Convert Dynamic Disk to Basic
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
2 minutes ago, seagate_surfer said:
Hello 42thgamer,
Thanks for the help! I just want to now one more thing: what is the difrence between the two?
Simple volume, is a dynamic storage which functions like a primary partition in Windows NT 4.0 and its older versions, can only be created on a dynamic disk.
Primary partition, is a partition which can be used to boot an Operating System, can only be created on a basic disk with MBR or GPT partition table under all Windows systems.
And is there a reason for changing it?
If you want to use the drive for boot purposes then yes. But if it works ok with your standards then avoid the hassle...
Sure! You are welcome! And I come here everyday so if you need more help I may reply within the next 24 hours, so feel free to post your questions here, this community is way helpful! :)
  • 3 weeks later...
You guys are too awesome for new guys like me!
