low power server build
Go to solution Solved by Electronics Wizardy,
8 minutes ago, 0100100001101111 said:
1000usd
Id probalby get a b30 board, and a i5 8400 and 32gb of ram.
How much storage do you need? Id get a 1tb ssd for boot and vms and a few hdds for storage.
27 minutes ago, 0100100001101111 said:
oh, and do I need to buy a nic?
You need to, but if you want this to be a router have 2 or more nics is very nice. Otherwise you need vlans. And id probably suggest keeping the router on anouther box. Makes it much easier to service the nas as it doesn't take your whole network down.
https://linustechtips.com/topic/973158-low-power-server-build/#findComment-11764896
12 hours ago, 0100100001101111 said:
what if ignore the low power for now
There aren't any itx 1366 boards, you need eatx for dual socket(some atx though).
Those chips aren't worth much anyways, so id really just get something newer.
https://linustechtips.com/topic/973158-low-power-server-build/#findComment-11767381
