i own a audia technica 2020 usb+ and i have it connected on a 2.0 usb(dont have a lot 3.0 slots and the one i have are ocupied). and am geting a new pc and am asking if there is a qualitydifference between 2.0 and 3.0? cause there is always a white noise in the micrtofone when i record things!
i will buy the asus maximus XI code and there shound be a 3.1 usbport. is this even better?
CPU: Intel I9-9900K Motherboard: Asus ROG Maximus XI CODE RAM: 32 GB Corsair Vengeance PRO 3200MHZ GPU: Asus ROG 2080ti OC Storage: Samsung 970pro 2x1TB, 2Tb HDD Case: Lian Li PC O11 dynamic, Cooling:custom loop incoming, for now 360 rog ryujin!
https://linustechtips.com/topic/973031-microfone-quality-difference-usb-20-and-30/
2 minutes ago, M.Yurizaki said:
Audio has so little bandwidth it shouldn't matter.
damn thanks for the info
USB 2.0 has a theoretical max. bandwith of around 40MB/s.
USB 3.0 has a theoretical max. bandwith of around 500MB/s.
Your typical pc audio stream does only require a max. bandwith of 576KB/s or 0.576MB/s.
In short: It doesn't matter.
Your typical pc audio stream does only require a bandwith of 576KB/s or 0.576MB/s.
Danke
Just now, Timotheus2 said:
What does matter is clean power over usb. A noisy power supply can generate noise in bus powered microphones.
yea am buying the corsair RMX850 80+gold! should be clean enough!?
23 minutes ago, Timotheus2 said:
Tier 1... sounds good
just looked my current one has the be quiet! System Power 700 Watt (80+bronze)
but its already 4 years old
Keep in mind the USB port may have more or less noise, unrelated to the USB 2 vs 3 status. So best thing to do is always test every USB port for noise.
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
The source of noise either has to happen at the microphone itself where the ADC is, the DAC at the output, or both. Anywhere in between is in the digital domain and noise should not affect the quality of the audio.
(Crap, I didn't want this to be my 15Kth post. Oh well)
Edited by M.Yurizaki
