None of my programs are showing up except for the taskbar and the only thing that opens is the start menu. Whenever I try to do a command like Ctrl+Alt+Del It just goes to a black screen for a minute then goes back. I've tried restarting it and shutting it down but have had no luck, I'm running Windows 10 64 bit
https://imgur.com/a/OFWyVQZ
https://linustechtips.com/topic/972776-programs-not-showing-and-opening/
How did you install windows?
Did you recently install a windows update?
Try unplugging it when it's off and then restarting?
This is my older computer and is a pre-built so I think windows 7 came installed with it then I upgraded to windows 10. I'm not too sure if there was a windows update when I've restarted. I tried your suggestion but it hasn't changed anything.
