Problem with creating pendrive partitions
Go to solution Solved by paddy-stone,
Use Rufus - Create bootable USB drives the easy way
And format it, then you get all the partitions wiped.
Okey, so i accitentaly put motioneye os on my usb drive, fortunately i didn't lost antyhing important, problem is that now i can't delete one partition in windows computer managment,. There is 20mb partition that is visible by windows, and 15 so GB unlocated memory space. I can't delete first one, and make partition from the second, any ideas or programs? I always used computer managemnt and it always worked. Keep in mind i'm now on W7, i can use W10 pc when i get home but it shouldn't be the case
Quote me so I can reply <3
https://linustechtips.com/topic/972506-problem-with-creating-pendrive-partitions/
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
10 hours ago, Gawron10001 said:
Worked, thnx
No problem, glad to help :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
