If it's not specifically on the box then no.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758069
2 minutes ago, HJ1009 said:
Yeah I guess it fits but only with a new support bracket which you can probably get online.
Can you take a picture of all the mounting hardware that came with it? Maybe one is correct but they didn't change the box.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758083
this is the only amd bracket i found
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758085
iirc that doesn't fit.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758090
any suggestion on cheap air cooler?
Wait, does it come with 4 individual small brackets? These might fit. Pleas check the manual for am4 installation.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758100
I use this Phanteks cooler, should be compatible. AMD: FM1/FM2/AM4/AM3+/AM3/AM2+/AM2 (stock back-plate required)
Current Build
CPU: AMD Ryzen9 5900X
CPU Cooler: Deepcool Gamerstorm Captain 240 Pro
Motherboard: ASUS ROG STRIX X470 Gaming-F
Memory: G.Skill Trident Z Neo RGB F4-3600MHzC16D 2x16GB
Video Card: EVGA 3080Ti FTW3
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 850W 80+ Gold Fully Modular
Case Fans: 2x Noctua NF-P14s redux-1500 PWM 78.7 CFM  140mm Fan
Monitor: HP x34
              LG 29UM69G
Mouse: Razer Basilisk
Keyboard: Razer Blackwidow Chroma V2
Controller: GameSir Tarantula Pro
Headphones: Sennheiser IE200 + Fiio BTR5 2021
Speakers: Logitech Z200 2ch Speakers
OS: Windows 11
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758166
3 hours ago, HJ1009 said:
the manual only shows am3/am3+ installation
Try contacting Coolermaster support first. Most manufacturers have free upgrade mountings for AM4. You need to provide proof of purchase to get it for free, otherwise you would need to pay for it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/972471-will-it-fit/#findComment-11758388
