Ethernet significantly slower than WiFi?
Ayala
I've been using the WiFi antenna that came with my gigabyte aorus gaming 5 motherboard, and was getting decent internet speeds, but that mostly came from having a very fast router. I routed an 100 foot ethernet cable through 3 rooms, which may be a problem, and connected it directly to my motherboard. I tested with ethernet and got 50 mbps download, unplugged it and got around 200 mbps on WiFi. Does anybody know why and what I can do to solve the problem?
As you already referred to its likely the fact that you have such a long Ethernet cable without any repeaters. But I don't know much more as to what else it could be. Lets see what else people say first. Before you go out buying repeaters.
You expect me to reply then you'd best QUOTE me so I can........thanks
                                           Simple PC Parts list to reference for other Users:
Case: Meshify C
CPU: Ryzen 1600 @ 3.8
Mobo: ASRock AB350 Pro4
Ram: 2 x 8gb (Corsair RGB Pro)
GPU: XFX RX 580 8gb - Clocks: Core @1386mhz, memory @2000mhz
Storage:
Boot drive - 120gb NVME Corsair MP500
Main Storage drive - 500gb 860 EVO
Archival/Backup drive - 2TB Black WD
Mouse: Logi M570 for work, and a G502 for gaming
PSU: EVGA Supernova G2 650 80+ Gold
OS: And of course Win 10 Pro, because Linux ain't fully baked yet.
Monitors: (27in monitors)
TN - VG278Q @144hz
IPS - VP279Q-P @60hz
The limitation on Ethernet is 100m so you're definitely in the clear there. Is there any damage to the cable? Does it run near any heavy electrical stuff that could be causing an issue?
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Check to ensure your router is set to 1000 not 100 in the port configuration option outside of that what cable are you using i.e. cat 5, cat 5e, cat 6 do not use cat 5 or lower
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
How can I check my router’s port configuration settings?
I wouldn't manually set it, you get weird autonegotiation issues when forcing it, that and he should be getting over 50 in that event to begin with
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
The purpose of looking was to ensure that it is not set manually if it is set correctly then he should check what cable is being used
The cable is a cat5e ethernet cable, but I still don't know how to check the router settings.
Mine looks like this, the ports are set to auto but the reason I say to look is yours may be set manually?
