How does a cartridge work?
Go to solution Solved by InMiseryWeSeekPancakes,
45 minutes ago, InMiseryWeSeekPancakes said:
( Also incase you don't know a cartridge is something that is connected to a tonearm and then connected to the turntable itself I expect you to know what turntables are at least are! )
The cartridge is something that dwells beneath the tonearm at the very end.
The stylus, or needle, is the smallest and perhaps the most important component of the cartridge. It is made from a diamond or other hard material, shaped like a cone and suspended by a flexible strip of metal. The pointed end is the only piece that touches the top of the record and it rides around the spiraling grooves of the disk, picking up the vibrations which are ultimately turned back into sound.
The stylus sits at one end of the tone arm, which is mounted to the side of the turntable and sits parallel to the record. With the needle or stylus placed in the outermost groove of the record, the tone arm follows the groove as it spirals inward, traveling across the record in an arc as the record spins beneath it. As this happens, the vibrations travel along a flexible metal strip and wires housed in the tone arm to the cartridge in the end of the tone arm. The cartridge receives the vibrations, which are converted to electrical signals through a coil in a magnetic field. The electric signals are carried along wires to the amplifier which enhances the power of the signal. Finally, the signals are converted back to sounds that come out through the speakers.
@Dan Castellaneta
My current code projects
  • C#/OpenGL ( using OpenTK graphics library API ) KnightsRealm ( unfinished, WIP plan on releasing on steam maybe a mobile port idk ) 2d topdown pixel art based game with medieval themes, sorcery, dragons, open world
  • C++ crypter ( if your into cryptography, I plan on releasing this on my website later :P
  • C#/OpenGL ( OpenGL for UI ) fan/light controller for my room w/ raspberry pi and some mechanical motors and stuff :D
Current repair projects
  • My dreadful receiver ( a capacitor blew )
  • working on a PC from a client, CPU died within the system, seems like a short, replaced CPU and awaiting payment before I ship it back
  • my old 1tb sas drive for my NAS, some blemishes or something on the PCB need to clear that back out, if it doesn't work i'll need to scrap it ( already backed up all my stuff thankfully )
    If you want any software made, or stuff to be repaired give me an email!
    mike.fernandez5138699@gmail.com
https://linustechtips.com/topic/971764-how-does-a-cartridge-work/
@Dan Castellaneta
@Dan Castellaneta I was just informing people on how these things work. Its one of my specialties.
Oh.
Maybe it's just me, but I guess the thread title should be phrased less as a question and more as an informational thread.
Also I didn't go that in depth just the foundation of it all. I apologize for it seeming like it was a question when really I was providing information.
