No. Buy a new PSU first, and not a shitty $20 one, but a proper one. What's the rest of your system?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
4 minutes ago, Tibon said:
You should find out why it exploded also.
Unless it's a really crappy and old psu which i doubt you were using.
I suspect there was a power surge when it happened. Might want to invest in a good voltage regulator or a good UPS.
how i can find what cause the explosion?
Doesn't matter what caused it, when a PSU fails it's better to just throw it away and get a new one.
Oh, and don't ever open a PSU.  The capacitors can hold a charge for months, and that charge can kill you.
FYI :
