I have a problem with my audio. I built a new computer that does not seem to have an all in one audio plug so i got myself an audio splitter so that i could both talk and hear. After doing this it is able to detect both, but the audio sent from my mic is being sent to my headset and not to e.g. discord.
I need some help
https://linustechtips.com/topic/970844-audio-and-mic/
Ok so let me get this straight:
You have a headset with a plug that has both audio and mic? So you bought a splitter that goes into the speaker port and mic port on your pc. Your pc recognises both devices seperately.
You are hearing the mic but programs aren't.
How did I do?
Send help
https://linustechtips.com/topic/970844-audio-and-mic/#findComment-11742476
How did I do?
i mean, still have the problem, but yes
https://linustechtips.com/topic/970844-audio-and-mic/#findComment-11742844
What does your splitter look like, if its just a aux female to 2 aux male splitter then its useless.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/970844-audio-and-mic/#findComment-11743020
If its a purpose built splitter that separates the channels and your pc recognises them, then do two things.
1. Check if under recording devices you have "listen to this device" enabled on your mic
2. Change Discord's input device from default to your mic
Maybe you've already done this but just in case.
Send help
https://linustechtips.com/topic/970844-audio-and-mic/#findComment-11743366
