Getting close to having the funds so thought I'd get some opinions.
Yes there is a ton of RGB but in the end it'll be color neutral with purple and gold lights.
https://pcpartpicker.com/user/BSS_Gaming/saved/CZW9Jx
Old PC is still decent but thinking ill strip and use what i can to upgrade my roommates 7yr old PC.
https://linustechtips.com/topic/969829-first-build-and-full-upgrade/
2 minutes ago, emosun said:
well there's a ton of wasted money to pad the budget , but looks fine compatibility wise.
True, I tried to do performance and aesthetic all at once. Though since I'm still about $700 short of my 3k budget goal I may switch to a pure performance build with a clean mat-black look.
1 minute ago, theblastman21 said:
Looks fine but why the 2tb ssd? Just have a 500GB ssd.
Sadly a 500Gb would get filled way too fast, though the M.2 could be swapped for a couple 1Tb SSDs and cost about half as much...and this is why I wanted opinions lol
Maybe you should wait for 9th gen Intel CPUs (the i9 9900K is rumoured to have 8 cores)
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Yea. Because I looked at the list and I'm like you spent more on your storage then your gpu. You should probably fix that.
“Security is always excessive until it’s not enough.”
– Robbie Sinclair, Head of Security, NSW Australia
“Have you tried turning it off and on again?” - Every Tech Rep Ever
If you need help with your build please tag me.
Main PC:
CPU: Ryzen 3 1300x RAM: 8gb ddr4 2666 MT/s Mobo: ASRock A320M HDD: 1tb WD GPU: Gtx 1050ti 4gb
P.s. if you can tell me what reference my location I will follow you.
Bonus points if you can tell me the names of the people there.
Build something like this ND save a few hundred bucks. I hv even added a 1080ti...
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($345.99 @ Walmart)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($88.99 @ SuperBiiz)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($158.98 @ Newegg)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Amazon)
Storage: Team - L5 LITE 3D 480GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.39 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 Ti 11GB DUKE OC Video Card  ($599.99 @ Newegg)
Case: Thermaltake -  View 71 TG RGB ATX Full Tower Case  ($139.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1683.20
Generated by PCPartPicker 2018-09-08 17:42 EDT-0400
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  ($169.99 @ Amazon)
Motherboard: MSI - Z370 GAMING PRO CARBON ATX LGA1151 Motherboard  ($129.99 @ Newegg)
Memory: Team - Night Hawk RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($154.99 @ Newegg)
Storage: Samsung - 860 Evo 1TB 2.5" Solid State Drive  ($177.99 @ Amazon)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card  ($704.99 @ Newegg Business)
Case: Cougar - Panzer ATX Mid Tower Case  ($89.96 @ Newegg Business)
Power Supply: Corsair - TXM Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Newegg)
Other: Phanteks PH-FF120RGBP Halos RGB Fan Frame – High density LEDs, RGB,  ($10.12 @ Newegg Business)
Other: Phanteks RGB adaptor ($3.79)
Total: $1898.16
Generated by PCPartPicker 2018-09-08 22:11 EDT-0400
