So I've been trying to play the BFV beta but my framerates are much lower than I expected. I'm getting 50-60 fps on low.
I'm running an i7-8750hq and a GTX 1060 6gb (it's a laptop). I've seen that BFV should run fine with a 6C/12T cpu, which I have, but framerates are still low. Any help would be appreciated! Thanks!
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/
A) you're on a laptop and laptops have horrible thermals. (99% of the time)
B) Battlefield games are notorious for being heavily CPU bound.
C) Combine A & B together and I bet you are having a horrible thermal throttle on your CPU as a result to try and keep temps in check.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/#findComment-11730148
I thought this might be the issue so I had AIDA64 open in the background monitoring the throttling and at least according to it, there was none.
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/#findComment-11730156
Maybe ram issue? I know the game uses more than 8gb of ram easy
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/#findComment-11730181
On 9/7/2018 at 6:09 PM, tp95112 said:
The game is in beta its normal. Also, remember to update video drivers, 3.99 I believe is the latest one. What frames rates are you getting? Have you tried it with dx12 on/off?
I have the latest drivers. I haven't really looked at framerates with DX12 but there's a lot of stuttering and random drops compared to DX11. In DX11 I'm getting between 50-70 FPS. CPU runs between 3.6-3.9 GHz
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/#findComment-11735878
is there even an option to switch bettwen dx 11/12? anyways i had mayor problems with stuttering in bf1 and bfv on a ryzen 2700x and gtx1080. tried everything and finaly got feed up with it last night. i had Windows version 1803 and reverted it to build 1607. all of the stuttering in both games is gone now
https://linustechtips.com/topic/969530-bfv-beta-low-framerates/#findComment-11736302
