Upgrading graphics card (help pls)
Go to solution Solved by NTDaws,
2 minutes ago, georgech900 said:
Thanks, also I thought there were only going to be 2070s and 2080s lol, but yeah ill keep it in mind, though it will cost a lot more than the others I assume. But currently what graphics card would you most recommend for my budget (excluding the price of the I3)
This
PCPartPicker part list: https://uk.pcpartpicker.com/list/4FwNq4
Price breakdown by merchant: https://uk.pcpartpicker.com/list/4FwNq4/by_merchant/
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  (£103.72 @ PC World Business)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  (£70.98 @ Amazon UK)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card  (£239.99 @ Ebuyer)
Total: £414.69
Generated by PCPartPicker 2018-09-06 16:14 BST+0100
or
PCPartPicker part list: https://uk.pcpartpicker.com/list/s97s3F
Price breakdown by merchant: https://uk.pcpartpicker.com/list/s97s3F/by_merchant/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  (£72.97 @ Amazon UK)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  (£69.99 @ Ebuyer)
Total: £382.95
I personally prefer a Intel build because of performance in games.
Okay, so I'm looking to upgrade my pc's graphics card and the cpu. Currently I have an i3 7100, gtx 1050ti, 8gb ram, 1tb hdd and 500w power supply. I'm looking to get my pc vs ready with a budget of £400. I will be getting the upgrade after Christmas when the prices have dropped after the rtx cards. I was considering a 1060 6gb mini currently but if I weather to get a 1070. Also if I what core I'd need to get but I was looking at the core i3 8100 as I found that's a good one for 1060s but I'm not fully sure, would really be happy if somebody could help me here :D
H110M-R - Motherboard type
https://linustechtips.com/topic/969088-upgrading-graphics-card-help-pls/
3 minutes ago, Being Delirious said:
i3 8100 would be okay for a 1070 and 1060, though I would invest in the GTX 2060 when it's releases.
This
Total: £414.69
or
Total: £382.95
lttstore.com
1060 is probably the best option, unless your gonna play at like 4k or something which i assume you're not going to. What games/graphics settings and fps target are you looking for?
This
Total: £414.69
Thx, best part is i have a compatible motherboard already lol
sos forgot to put my reply in a reply attachment :/
well I'm looking for at least a steady 90fps and above in most vr games , basically capable of a great vr experience, and also to be hitting above 60fps on full in basically all games on full settings.
6 minutes ago, Being Delirious said:
Your board is not compatible.
Oh, I see I checked the part picker, thank you for this info I had no clue lol.
Does installing a new motherboard requires using BIOS stuff or just plugging the stuff in the same place lol (sorry I haven't built a pc before and I have no clue lol)
Ik how to install a graphics card and the core tho :)
Would be very happy if you could help or link something which already explains this lol
Thank you :D
Thank you :D
Not typically no
lttstore.com
