CPU stuck to heatsink - thermal paste remover and floss didnt work
InsertName
The cpu is stick to the heatsink, I tried thermal paste remover and floss and it didnt work. Any other ideas?
is this thermal paste or thermal glue ?
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
Im unsure, it is quite an old system
Have you tried turning on your computer for a while to heat up the thermal paste and then trying to take it off? The simple twist method should work.
It is already out of the system.
Do you have the motherboard for it? Just plop it in and short out the power-on pin and let it run for a min or two.
Sounds like thermal epoxy.
Though if it is normal TIM, just heat it up , should come of easier.
If not , try some acetone.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
I am sure its thermal glue
Get yourself a small bowl or something similar.  Put some denatured alcohol in the bowl and then put the cpu/heatsink in the bowl and let it sit over night.  We're not trying to drown the cpu but just put enough alcohol in the bowl to cover the joint where the cpu and heatsink join.  Letting it sit over night should allow the alcohol to do it's think and soften the paste/glue to the point where you can twist them apart.  Good luck.
