I have a Dell s2716dg monitor. I have had it for a couple months and have enjoyed it. The other morning when I woke up, I went to turn on the computer an the monitor would not turn on and just makes a continuous beeping sound every couple seconds. I tried unplugging it and unpluged the display port cable as well, but it just keeps beeping when I plug it back in. Should I take it back to Best Buy to see if they will replace it or is there something I can do to fix it?
CPU i7 8700K ( 5 GHz) RAM G Skill Trident Z 32 GB (3200 MHz) GPU EVGA RTX 2080 XC Ultra Motherboard Asus ROG Strix z370 E Gaming Cooling NZXT Kraken x62 R2 PSU EVGA SuperNova 650 W 80+ Platinum Storage 500 GB Samsung 970 EVO NVME M.2, 1TB Samsung 860 EVO M.2, 1TB Samsung 850 EVO SATA, 1TB Samsung 860 EVO SATA Display Dell QHD 144Hz 27'' Case NZXT H500 Black Keyboard Corsair K95 RGB Platinum Mouse Logitech G900 Operating System Windows 10 Pro
https://linustechtips.com/topic/966597-help/
@MattKnutson84 Hell yeah take it back IF you paid for the insurance thingy which I believe is $50.
I picked up one up a couple of weeks ago and I made sure that the monitor was manufactured recently -- mine was June 2018 while the others in stock are Nov 2017.
twitch.tv/oliv_r
https://linustechtips.com/topic/966597-help/#findComment-11702503
Can you describe the beeping? Or is it more of an electronic hiss
https://linustechtips.com/topic/966597-help/#findComment-11702506
A monitor shouldn't be beeping. a beeping sound is coming from your computer....
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/966597-help/#findComment-11702539
It actually is coming from the monitor. I turned off the computer and shut off the PSU, and it still beeps. I can hear it on the monitor if I put me ear up to it. It is a short beeping every 2-3 seconds.
https://linustechtips.com/topic/966597-help/#findComment-11703418
You would think it is under warranty if it's only been a couple months.
https://linustechtips.com/topic/966597-help/#findComment-11703422
It is a short high pitched beep every 2-3 seconds.
https://linustechtips.com/topic/966597-help/#findComment-11703424
Curious.
Pull the power cord and video cable from the computer. See what it does.
https://linustechtips.com/topic/966597-help/#findComment-11703445
1 hour ago, Radium_Angel said:
Curious.
Yeah I tried that but when I plug it back it it starts beeping again.
https://linustechtips.com/topic/966597-help/#findComment-11703674
What I meant, was pull the power cord from the computer *only* (plus the video cable, from the computer *only*) and with the monitor isolated from the computer, turn it on, and see if it beeps.
I bet it won't.
https://linustechtips.com/topic/966597-help/#findComment-11704961
I bet it won't.
I have moved the monitor to a different room plugged into nothing but the wall outlet and it still beeps.
https://linustechtips.com/topic/966597-help/#findComment-11706194
Ok, it's weirdly defective then. Never heard a monitor beep before, but I've heard plenty of motherboards do that
https://linustechtips.com/topic/966597-help/#findComment-11706429
I know right?! I'm pretty confused. Well, thanks for the help though.
https://linustechtips.com/topic/966597-help/#findComment-11707081
If possible, before you return it, can you upload a video/audio of the sound, I really want to hear what it's doing
https://linustechtips.com/topic/966597-help/#findComment-11708226
I'll see if I can do that. I took it to Best Buy and they said they couldn't replace it, but they gave me a number for Dell's monitor support and they're going to send me a new one within 2-3 business days with postage to return the defective one. I was VERY impressed with Dell's customer service.
https://linustechtips.com/topic/966597-help/#findComment-11713698
