My PC mobo has no onboard wi-fi so i used an adapter that connects via USB. The PC then starts to detect only close wi-fi signals. Once connected to the router the internet signal on all other devices on the same network drops. I tried connecting other devices and laptops to the router to see if it is a router problem. They seemed to work fine. Then i connected my PC to my phone's wi-fi and found that it failed to connect. I updated the driver on the USB adapter but it still didn't help. Could i update something else on the mobo that could help? Or maybe it is an OS problem?
Wifi Adapter: Edimax 150Mbps 802.11bgn
Mobo model: Asus H81-i plus
OS: Windows 10 Home
https://linustechtips.com/topic/966260-wifi-problems/
OS: Windows 10 Home
the Router you have.  Is it dual band?
The reason i ask is that dual band routers are able to have mixed signals.  I.e. 802.11b and G at the same time.
Single band routers cant.
and if it is single band, and its setup to autonegotiate the signal, it may be taking the router to a signal that nothing else you own is setup to use.
We used to have this problem with an old scale we have that was Wi-Fi enabled for weight tracking.
when we would connect it, all the other devices would loose service, because it was on a different signal type.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/966260-wifi-problems/#findComment-11699389
Wireless B and G are 2.4 GHz standards and any 2.4 GHz router can mix with both devices connected. It will choose the lowest speed in the chain for all devices. Many routers now days have the ability to restrict older devices from connecting so it don't slow down the network.
Dual band means it has 5Ghz as well. 5 GHz has the speed 2.4 GHz has the range.
https://linustechtips.com/topic/966260-wifi-problems/#findComment-11699447
...yes
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/966260-wifi-problems/#findComment-11699471
16 hours ago, Donut417 said:
You made the claim that you need a dual band router for B and G to run on the same router. Thats completely wrong.
Im sorry senpai
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
https://linustechtips.com/topic/966260-wifi-problems/#findComment-11702529
