welcome to the world of laptops.
it thermal throttles because it's a laptop and is hot and can't cool itself , which isn't a new thing.
it power throttles because it doesn't have as much power running off the battery as it does when it's plugged in. Again  , not a new thing either.
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11694927
Is there any fix for this? I even undervolted my cpu by -0.165 volts and still getting these issues
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11694948
in the short term? set the cpu maximum power state to like 50% in the windows power settings.
in the long term? use a desktop , this is what they are made for. they are made to be used heavy and run cool
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11694955
Thanks, but setting the cpu maximum power state to 50% will reduce the performance of the laptop and I'll mostly be travelling, that's why I use a laptop for intensive tasks.
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11694992
Yeah , if you want it to run cool ... you have to prevent it from overheating ... by reducing the amount of work it's doing.
Again , it's not a desktop. It's not going to run infinitely fast and never overheat. There's no solution for that.
The solution is to use a machine that is designed to do that.
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11695010
That model need LM in order to solve thermal issues
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/965786-throttling-issues/#findComment-11697996
