*edited*
the 460 is faster, but the 650 has more features and more VRAM which would help with higher res textures. its hard to find relevant benchmarks really but the 460 seems to be faster in the ones i can find
Builds:
https://linustechtips.com/topic/965208-help-me/#findComment-11689265
1. no one can guarantee how much longer these cards will work (for all used parts)
2. their performance is basically obsolete in 2018, this goes back to purpose of you buying the GPU.
IMO, only suitable for casual old games or connect dual monitors...
for more competitive, you should look for at least used GTX750ti or AMD r9 280
https://linustechtips.com/topic/965208-help-me/#findComment-11689652
the #1 that is only thing that's stopping me from buying any of the card
that's the thing i've found gtx750ti and some good gpus but i don't have money for that, they're too expensive for me and i'm stuck between these two and don't know which one should i choose, but they're in good price for gtx460 $31 and for gtx650 $40.
which one do you suggest out of two
https://linustechtips.com/topic/965208-help-me/#findComment-11689705
23 minutes ago, dgsddfgdfhgs said:
all I can say is, forget the 460, its even 2 years older than 650.
but anyway you will not be satisfied with any of these, current amd APU beats them (cpu with on board graphic performs like GT 1030)
i don't understand so you're telling me to buy cpu but not gpu i don't really know what amd apu is (i think it's cpu right ?)
https://linustechtips.com/topic/965208-help-me/#findComment-11689764
amd apus ar accelerated proccessing units, as ryzen vega apus take ram memory for graphical operations. The only thing different is ryzen vega apus limits the core usages, for instance if it has total 8 cores, 2 of them are dedicated for graphical operations and how much of your ram memory you are spending for it. As higher the memory size dedicated for graphical operations the faster the integrated gpu will perform.
https://linustechtips.com/topic/965208-help-me/#findComment-11689793
This guy is ?% correct. You're better off getting a Ryzen chip instead only. Like a Ryzen 5 2600 or something. That will give you better frames tbh. Your GPU would bottleneck it, and when a GPU is bottlenecking the CPU... You know there is a problem.
https://linustechtips.com/topic/965208-help-me/#findComment-11689805
The Ryzen 5 2600 does not have a APU...
Ryzen 2600 - Sapphire Pulse Vega 56 - Corsair Vengeance LED DDR4 3000 C15 2x8GB - Corsair Force MP500 NVMe PCIe M.2 240GB - 2x Seagate Barracuda 2TB -
AsRock B450 PRO4 - Deepcool Earlkase Case -  Seasonic Foucus+ 650
https://linustechtips.com/topic/965208-help-me/#findComment-11689808
