What are your temps? Have you tried lowering fan speeds?
Moved to Air Cooling.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11689147
Some new thermal paste should make the stock cooler good again.
Desktop benching:
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11689160
This is when i have open only browser with yt. Click for bigger image. This is not the problem, its quiet right now.
Second picture is when i play games for 20minutes, he becomes very noisy, this is the reason why i want to buy another.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11689712
Temps aren't that high -- it's fine up to 80-90c at load. You can afford to lower fan speeds a bit.
Are you sure that the noise is from your cpu cooler and not elsewhere in the system like on the graphics card? Does stopping the cpu fan with your hand stop the noise?
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11689781
26 minutes ago, stefs said:
Can i stop?
I am afraid from thunder.
Stopping the fans with your hand is fine as long as they're not dangerously high rpm. The Intel stock cooler blades are rather thick and not dangerous. No, you won't get shocked.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11690646
@@WoodenMarker
Thank you, you save me from spending money without any reason.
Its not CPU its GPU!! Cpu is not too much loud.
Now, i watch in site, and see that newest bios is F3, and they improve performance.
https://www.gigabyte.com/Graphics-Card/GV-N105TD5-4GD#support-dl-bios
How to see bios in my graphic and update if i want?
In hw info i see this: Video BIOS Version:    86.07.39.00.57
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11693088
Have you tried the Arctic Freezer 11 LP I was refering to earlier?
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11693104
Don't update the bios if you don't need to since an error can potentially brick the card.
What case do you have and how is the case airflow set up? Temps are abnormally high for a 1050 Ti with fans at 2000rpm.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11693746
3 hours ago, stefs said:
I think this is the problem, i dont have fans in my case. This is the reason why my case is always open.
Case is: https://ms-start.com/ms-cyclops-iii-midi-tower-gaming-kuciste.aspx
Do you have suggestions for fans?
Where are you shopping / located?
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11695551
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11697351
16 hours ago, stefs said:
The cheapest solution would be to add a rear exhaust: https://www.grooves-inc.com/arctic-gmbh-120mm-arctic-cooling-f12-pro-arctic-gmbh-hardware-electronic-pZZa1-2097970575.html?osCsid=7f06243340d92ebcf0c00e2fdde0c44f
It can only be mounted one way in push so keep that in mind if you want to reuse it in a different location for a future system.
If you want more flexibility, you could use the normal F12 rev. 2 instead. It performs a bit worse but can be mounted in pull: https://www.grooves-inc.com/arctic-gmbh-120mm-arctic-cooling-f12-pwm-rev-arctic-gmbh-accessories-pZZa1-2098043196.html?osCsid=7f06243340d92ebcf0c00e2fdde0c44f
You can add a second fan at the front as intake if you want more airflow.
If you want something particularly quiet, PW2's: https://www.grooves-inc.com/quiet-pure-wings-120mm-pwm-gehaeuseluefter-bequiet-hardware-electronic-pZZa1-2097677670.html?osCsid=7f06243340d92ebcf0c00e2fdde0c44f
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11700083
1 hour ago, stefs said:
@WoodenMarker
Do you think 2 pc of Pure wings 2 will be enought?
1 rear exhaust is already enough and an additional front intake is plenty.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11700574
  • 3 weeks later...
On 9/18/2018 at 2:14 AM, stefs said:
I get  2 pc of Pure Wings 2, can you tell me where to put and in which side?
Thanks..
1 rear exhaust and 1 front intake.
https://linustechtips.com/topic/965186-g4650-cooler/#findComment-11771460
