My build, RYZENONE, is about a year and three months old now. I'm thinking of replacing the thermal paste of it since the idles of the device is now at 50 degrees, as opposed to 40 when first bought.
Now, local retailers has a couple of choices available: the three Cryorig thermal pastes (CP5, CP7 and CP15), the Noctua NT-H1, and the CoolerMaster MasterGel Pro and Maker, priced as follows (I'd put in other brands here but they're generic):
CP15 - ~5 USD
CP7 - ~7.50 USD
CP5 - ~9.50 USD
NT-H1 - same as CP5
MasterGel Pro - ~10.50 USD
MasterGel Maker - ~13.50 USD
Now, the general knowledge is that unless its liquid metal, thermal pastes produces little to no difference from each other. So, my inquiry is that would it be okay for me to get the cheapest, decent tube available (Cryorig CP15) and call it a day or shell out a couple of bucks more to get either a CP5 or a NT-H1?
I don't think it matters, but I'll put it here anyways: I'm planning to use the same thermal paste that will be bought on my laptop, and I don't mind using the same tube when re-applying again in the future.
https://linustechtips.com/topic/964899-thermal-paste-recommendation/
Thermal grizzly kryonaut for air cooling or hydronaut if you have a water cooling solution. Idk about conductonaut.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
Its about personal preference more than anything else. I've had Noctua coolers, so I buy Noctua paste. But I also prefer tube that comes with cooler over buying something else just because.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Are you sure that there aren't more processes running in the background now than when you last tested for idle temps? Are your load temps any higher than before?
recorded a couple of temps this morning (all in celcius)
BIOS idle temp was 37-44 degrees
Windows idle was 46 per AIDA64, but 54 per HWMonitor
MemTest(1-pass) - 50-51
AIDA64 load had an average of 64.2, but HWMonitor reports 79
1 game of a 50v50 in Fortnite yields 56-59, but HWMonitor records 65
i call the HWMonitor results fishy tbh, but do these temps warrant a TP replacement?
Have you tried using Ryzen Master for temps?
Updating the bios if it isn't already and using the latest versions of these programs might get them to agree.
updated the monitoring programs, as well as intalled ryzen master: on consecutive 50v50 games in fortnite, aida64, HWMonitor and ryzen master reports 60-70 degrees,
at this point, i'm almost sold on buying a cp15 and calling it a day
Unless it's throttling and you're having performance issues, it's using a 20c offset. Those are fine temps and won't throttle until 75c.
So don't change thermals for now, but do so when temps get to around 75-80?
Temps are fine and it doesn't seem like changing the thermal paste would make much of a difference if any.
