Hello everyone,
I got Ryzen 5 1600, recently I bought it and decided to do some OC. I hit 3.9 Ghz at 1.319V MAX (after whole day of usage checking CPU VCORE its max 1.319 and same for the CPU VDD).
Today I noticed that the max values have changed, CPU VCORE is 1.341V max value, and CPU VDD is 1.331V Max value, what made this change ? Is my CPU degrading from OC? Everything is still stable and temperatures are fine.
https://linustechtips.com/topic/964653-possible-cpu-degradation/
9 minutes ago, Cianthy said:
Hello everyone,
Paranoia is a disease, don't let it consume you. Everything is fine, you probably have it on auto voltage regulation that pulls more juice when system works hard. Everything is fine.
3 minutes ago, Cianthy said:
My Voltage is set on offset so its fixed, but LLC calibration is on auto, could LLC be changing voltage?
Tho why would it change ? Its been like this for 2 weeks, and today I notice a change ?
LLC stand for Load Line Calibration I think.. It will raise voltage when needed. if it only happened today, it means CPU doesn't really need more than what you set it to be, so.. everything is fine. A healthy overclock, normal voltage levels.. I think you're good. No need to be worried.
It could very well be your auto LLC setting or that you're using offset (offset isn't fixed) to control your voltages.  A CPU needing higher voltages is a sign of degradation, however, at the voltages you have been running I don't think it's your problem.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
