For some reason, that one cable is realllllyyyy bothering me. Other than that it's fine. Maybe vacuum a bit :D
actually those are stains I need a new carpet just waiting till the dogs are fully trained
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1290624
They just don't look like 1080p monitors. The one on the right looks like a completely different aspect ratio.
see what ur saying just the pics tho. I need to upgrade my monitor soon tho on my list right behind 4 pwn fan extender cables. :) hopefully i can get some cash from shoveling in a day or so blizzard comming my way
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1290634
Mmmmm, G710+. I got mine, and I am loving it.
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1290648
I think it's because one has the task bar, the other doesn't.
That's a lot of stuff piled onto a couple of desks!
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1290668
I have no desk space. And I wish I had the patience to do this.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1290679
Have fun with those zip ties when you come to replacing something or you just want to move something to another computer. I prefer going with velcro ties or if funds are short get a roll of that garden wire you know the plastic covered stuff, its the same stuff that most cables come tied up with.
And yes I know that you can cut off and then replace the zipties but i cant look past seeing that as a waste.
Star Citizen LTT Conglomerate Wants you! Join now!
UOLTT Basop | Misc Freelancer & Origin M50
Outside of a dog, a book is a man's best friend. Inside of a dog it's too dark to read.
-Groucho Marx
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1292396
its actually one L desk and yeah I know. It contains 2 pcs 3 monitors 2 routers 1 network switch 2 of my 5.1 speakers 2 keyboards 2 mics 2 headphones/headsets, 2 mouses, ect.
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1292676
I see ur point. luckily thats why I waited untill I was pretty much done upgrading my peripherals and such.
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1292682
That desk looks really nice do you mind sending a link for it?
My build: Cpu: (AMD Ryzen 7 1700) Heatsink: (Deepcool Captain 240 rgb) GPU: (Zotac AMP! GTX 1060 6gb) Ram: (Corsair LPX 8Gb DDR4 2400) Mobo: ( Gigabyte AX370 Gaming K&) Case: (NZXT Phantom 410 Gunmetal) PSU: (Lepa B550 550w) OS:  (Windows 10
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1292716
it's on amazon search gaming desk that's what I did I would link it but I'm not at my PC right now and won't be till later tommrow
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1296296
okay thanks i'll try to distinguish from the legs
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1296527
Peg boards and mirror hooks are actually great for that if you're willing to put a couple of holes in your desk. Been using this trick to great effect.
i would and actually I have a glass drill bit but u have to have water on it and stuff to cut holes in glass so no point
https://linustechtips.com/topic/96434-desk-cable-management/#findComment-1315887
