Custom Watercooling help
Go to solution Solved by For Science!,
18 minutes ago, Randycool279 said:
Cool! I'm thinking I will run the loop first from the pump to my 420mm rad which will go to my 2990wx, then it will go to the 1st and 2nd graphics card. Then it will go to the 2nd 420mm rad and back to the pump. And one question, if you did face a problem with air bubbles, how did you get rid of them?
Thanks!
Tilting the case, changing the pump speed helps with air bubbles. Loop order tends to be inconsequential to performance so do what is easier for the runs. Mines goes from Pump --> --> 240 rad --> 420 rad --> 4 x GPU --> 420 rad --> 1950X  --> pump
Hey guys,
I’m going to be doing a full custom watercooling loop for a customer in the Corsair 1000D case. I have a AMD Threadripper 2990WX, 2 Titan Xp's and an ASUS Zenith Extreme. I am going to be using soft tubing for this build with 10/13" tubing. I don't know on what type of radiators and what size I should be using. I used the EKWB custom watercooling configurator and it recommended 1 420mm rad for the CPU monoblock with a pump/reservoir combo. Then it recommended one 480mm for the 2 titans with a pump/reservoir combo. I wanted to know how I should setup the loop, should I keep the 2990wx on one seperate loop and the gpus on another? Or should I use the 2990wx with the 2 titans on 2 different rads with 1 pump?
Thanks!!
https://linustechtips.com/topic/963949-custom-watercooling-help/
That sounds like a really badly planned PC, what are you going to use it for?
lmao yeah it is horrible planned pc... But I had the 2 titans from my other workstation and I just recently bought the 2990wx. I do a lot of CAD work with 4-8k video rendering. My old system was a i7-4790K with originally two 980ti's but had upgraded to 2 titans which is going to be in this watercooling build.
6 minutes ago, Randycool279 said:
Fill the system with as much radiator space as possible, and put everything in a single loop. Here is my 900D build with 4 1080Tis and a 1950X. For this system I used 2 x 480 radiators and 1 x 240 radiator.
Thanks!
Thanks!
