Front Mounted Radiator Cooling Question
Solved by W-L,
56 minutes ago, Cozmo555 said:I would like to build a dual loop where front radiator would probably be for exhaust. I'm afraid that the air pressure would drop as it hits the panel and gets forced out the side.
Am I wrong in thinking the front radiator is used for outtake?
I would use it for intake still, the solid panel will have an impact more so than an open mesh but as mentioned the air passes by the side vents along the two edges.
