So i've been having about 50% ich of my ram being used by nothing for around 2 months now and i can't seem to fix it, i have aleady disabled superfetch an enabled it multiple times, swapped the memory sticks but i can't fix the problem, also i can't update windows, every time it finishes updating a message pops up saying that it couldn't complete the updates. i think it has something to do with the boot drive but idk.
my specs are:
i5 6500
g1 sniper b7
2x8 hyper x fury ddr4 2133
gtx 1070 zotac amp extreme
corsair  cx600
generic 500gb hdd (boot-drive)
toshiba 2tb hdd
https://linustechtips.com/topic/962658-how-do-i-fix-a-memory-leak/
my specs are:
i5 6500
g1 sniper b7
corsair  cx600
toshiba 2tb hdd
You turn your PC off...
...and then on again! Either that or uninstall goldfish.exe
(Yes that should solve the problem but I shall actually get to solving it...)
OK so is this as soon as you restart or is this when your PC has been running for a while?
Edited by TechMasterMind
i7 8700k 5.0GHz 4.0Ghz Cache (Stock Cooler)
2x8GB 3400mhz RAM 19-19-19-38
GTX 1060 3GB 2050Mhz Core, 9500Mhz Memory
my specs are:
i5 6500
g1 sniper b7
corsair  cx600
toshiba 2tb hdd
What settings are you using for your page file? make sure it is on Auto.
That being said windows will try to keep a certain amount of information in ram. So having 30-50% used out of 16gb isn't unheard of and just means you can access those programs faster. It should clear things out as you start needing more ram. I also mentioned the page file, because if you have it manually set to low or disabled then windows cannot move lower priority things out of memory and also cannot optimized your memory effectively.
If youre having issues with update go to the troubleshooting page in control panel and you should be able to get to a list of troubleshooters... Run the one for update. It may fix that issue for you
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
my specs are:
i5 6500
g1 sniper b7
corsair  cx600
toshiba 2tb hdd
When the problem happens, can you post a screenshot of Task Manager -> Performance tab -> Memory page?
  • 2 weeks later...
2 hours ago, jared hernandez said:
sorry for not responding but here it is
I also should've asked for the "Processes" tab as well, but otherwise this likely means some app is leaking memory.
Also the "Details" tab, but sorted by descending memory usage (click on the "Memory" header thing and it should sort it)
