Need help with my Server and Backing up
Go to solution Solved by Salacious B Crum,
3 hours ago, AverageAfro said:
Hey guys! So I've got a server set up (unRAID) with Nexcloud running on it among other things. I've hit a wall on how to organise all my backups. What I have atm is just windows backup backing up to external HDDs. This works fine as I'm at home and I can just easily duplicate these backups onto a seperate HDD, but I'm moving back to Uni in a couple weeks so I've been setting up this server as a way to get around that.
I'd like to have a backup on each of our HDDs (Sorted), then a copy of those backups on the server, a copy of those back ups on an external HDD that's plugged into the server once a week, and then a copy of my Mum's backup on my HDD.
I'd also like to use the Nextcloud client sync for my Mum, and set up my own smaller NexcloudPi and use that for incremental on my computer, although I might change this to just use a backup program and mount the shares as drives so as to limit the amount of personal information going over the internet. Unless there's a way to get the Nextcloud sync to only sync over LAN?
What I don't know how to achieve: Getting a backup of the Nextcloud Share, and a copy of my Mum's backup to my own HDD over the internet; and then a backup of my computer and cloud onto my home server
I have a couple ideas. Syncthing, Duplicati and Nextcloud Federation folders. I've just no idea how to do it and all my googling is just confusing me.
You should post on limetech's forum they are a helpful bunch you'll get the answer your looking for over there
https://linustechtips.com/topic/962085-need-help-with-my-server-and-backing-up/
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
