I just built this system finally got to the point where the system isn't randomly freezing. Having issue where the edc is at 97-100% and sometimes throttles to about 2.1 ghz. temps range from 40c-120c depending on the program used to check temp.
cpu: 2700x
motherboard: asrock x470 taichi
power suply: evga gq 750 watt
gpu: evga gtx 1070 TI
ssd: samsung 850 pro
hdd: SEAGATE IRONWOLF 8TB HD
ram: 32GB g.skill ripjaws v 3200
cooler: corsair h100i pro rgb
cooler: corsair h100i pro rgbissue4.thumb.jpg.5e881d38a47f2aa629095437908b6317.jpg5b791bfabe8b8_issue6.jpg.a18717c5dd57ab8c67c85e355969fdc1.jpg5b791bf99691d_issue5.png.fa8bf42ab07dfedcecb8c3bdd269f546.pngissue3.thumb.jpg.8bf1cc5eb2410365e371227228d0aedd.jpgissue2.thumb.jpg.5a0e5cd214a4ceb985e172dbc850a149.jpg
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/
Check the Heatsink, is the Pump working, does the Base have contact, no sticker on the Cooler, Paste between Cooler and Heatsink.
Case Temperature?
How does it look with the Boxed Heatsink??
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11660425
Case Temperature?
the pump is working, it should i reset it and cleaned and reapplied thermal paste, nothing on the cooler, didn't try the stock cooler. case temp should be good if the motherboard is runing at 40c
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11660443
Is it overclocked at all? If so reset to optimized defaults and check again sounds like major instability
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11660975
@jamesbondlq You can't use High Performance with the 2700X if you want XFR or PBO to function properly. I didn't see anything odd in your screenshots temperature wise but I do see it isn't using its full frequency range and this is because you're using a High Performance power plan. Change that to Balanced. If you want to use Ryzen Balanced then you will have to change within that:
change advanced power settings>Processor power management>minimum processor state>20%.
Windows balanced defaults at 5% which is fine, but AMD Ryzen Balanced defaults to 90% which is fine for first generation Ryzen. The 2700X needs the value to be 20%.
Also, Windows changes the value to 100% a lot. I have to change it back constantly to 20%. I haven't figured out why yet.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11661550
that seemed to have fixed it kinda. It under volts to about 0.8 volts and under clocks to about 2.2 ghz like that a lot. while in games it still pegs the edc to 100% and only boosts to about 4 ghz but drops down to 2.2 alot and goes to about 70c in gaming.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11662161
Which motherboard do you have?
The .8 and the 2.2 are normal.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11662321
Ok then you should be able to use PBO. You can try in Ryzen Master, but I would recommend just doing it BIOS. Check under Advance AMD CBS or NBIO and look for Precision Boost Overdrive. You can enable it and then set the multiplier.
Also, you might be able to manually raise EDC however I would just suggest using the multiplier.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11662718
it was set to auto as defult. I set it to enable. it boost up to abouti seen it go up to 1.53v. it also bumped up the power avaiable  to edc (650 A vs the 140 A) but also is only siting at around 7% and spiking up to 32%
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11663294
Sounds good. You should see your multi-core sustained usage have higher speeds or at least stay higher for longer depending on which multiplier you selected in PBO settings.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11663313
  • 3 weeks later...
I have the same edc cap on my 2700x. I have an Asrock 470x Master SLI motherboard and in the bios version that it comes with, there is no option to enable anything.
What bios version are you running?
I have never updated bios in my entire life and i'm a bit scared of doing so.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11723583
Scroll up and you'll find the solution to your EDC issue.  You have to make an adjust to the power plan you're using.
Also, updating a BIOS is simple.  Just give it a go.
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11723678
Now i did find the setting to enable PBO in my BIOS. It worked fine for a day but now my pc doesn't want to boot if I have it enabled. It's pretty strange since it shouldn't have worked in the first place I believe. Now the Asrock master SLI motherboard has had some controversy around it not having the power phases that it boasted on launch. My temps on the vrm's were fine and there was no strange behaviour while i had PBO enabled. My power supply should be sufficient to power my system but i'm going to double check. Is there anything you could think of that would be the issue?
(addressing your last comment. I have read the entire convo carefully and i have made changes to the power plan, but it still instantly caps to 140a when doing the slightest of gaming, now while I had PBO enabled the cap was raised to 220a (James got 650a which is interesting) and i got no cap anymore.)
Cheers
https://linustechtips.com/topic/962052-ryzen-2700x-edc-issue/#findComment-11749246
