What PSU is this?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11659837
Well I can see one of your 4-pin CPU cables plugged into the top left of the motherboard but I can't see the second. I can see your 24-pin on the right side plugged in. I can't tell if your SSD is plugged in and if your power switch cables that come from the top of the buttons on your case and connect down into your motherboard into some called like power switch. Only other thing would be the external plug that goes from the wall socket to your PSU/
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11659886
58 minutes ago, cbranham26 said:
My main concern is there is nothing plugged into the BACK of my power supply to even plug into the motherboard
The 4 (or 8-pin) CPU power connector only fits in two of the modular connections on the power supply side.
You can use any of the 8-pin ports labelled under  "6+2 PCI-E & 4+4 CPU".
The other connections are 6-pin ports, labelled under "Peripherals & SATA" ... which only work with SATA power cables, and 4-pin molex, etc.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660002
I just took out my power supply. So nothing is plugged in back there. I have several cables, none of them explicitly say CPU. can someone show me what cable is supposed to be plugged into the back of this power supply, and once i do, does anything need to be plugged into the motherboard.  I am slowly losing faith i can do this.
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660010
The picture that you posted of your motherboard with the cable going to the top-left corner.
That goes to ANY of the 8-pin ports on the power supply under the "6+2 PCI-E & 4+4 CPU" section.
Have a look at the picture I uploaded in my previous post.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660021
5 minutes ago, cbranham26 said:
Ok i just plugged these in now there is a pcie that  looks too short to plug into  anything.  Is this correct?
Oh boy...
The 8-pin does connect to the power supply end, which you have is correct.
The daisy-chained 6+2-pin AND 6-pin DOES NOT go to the power supply ports -- it connects to your VIDEO CARD.
You also have a CX 650M and NOT and CS 650M.
Two different models.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660029
3 minutes ago, cbranham26 said:
The cable labeled cpu does not fit in the back of my powersupply. I give up
The CPU power cable...
One side is a SOLID 8-pin -- that goes to the solid 8-pin socket on the power supply, under "6+2 PCI-E & 4+4 CPU".
One side is a 4+4 pin connection -- that goes to the motherboard socket on the top-left corner.
There is a locking tab, so it only goes in one way...you can't properly connect it up-side down.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660043
Picture:
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660045
2 minutes ago, cbranham26 said:
This cable only has one end. The other is stuffed inside the case. Where  do i plug it in?
Cpu power is the name of the now blank mobo spot
That is the 4+4 CPU power connection.
That goes here:
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660056
I will plug the cpu cable back into the mobo. That still leaves the back of my psu empty other than sata
CPU 4+4 pin goes to the motherboard <<>>  8-pin from the other end goes to the power supply socket.
24-pin goes to the motherboard <<>> other side is directly connect to the power supply, so nothing to do there.
IF you have a video card, use any of the necessary 6-pin or 6+2-pins <<>> 8-pin from the other end goes to the power supply socket.
Connect SATA power cable to your SSD  <<>> you can either use the SATA power cable that is completely attached to the power supply, or use a modular one.
Connect the SATA data  cable to your SSD  <<>> Connect the other end to the SATA data ports on your motherboard.
Connect the case power button, reset button, LED indactor wires to the bottom right corner of your motherboard.
REFER to your MOTHERBOARD and/or COMPUTER CASE user manuals on how those should be connected -- will vary between motherboards (or case).
Make sure the CPU heatsink is installed, and the cooling fan cable is connected to a 4-pin CPU_Fan header
Flip the switch on the back of the PSU to the "ON" position.
Press the power button to turn on the PC...
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660096
Might has been a little easier if you started with a non-modular power supply for a first-time ever PC build.
Eliminates some of the first-time confusions.
Live and learn!
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/961986-cpu-and-psu/#findComment-11660107
