I print this model and it works fine
specs:
g4560 cpu
asus h110i plus mb
8gb ddr4 2133
120ssd + 500gb hdd
Pico psu  + 12v 6A power adapter outside
Deepcool htpc 200 cpu fan
Jonsbo solar eclipse case fan
any idea how put graphics card in it ?
(not with pcie x1 riser)
https://linustechtips.com/topic/961870-3d-printed-mac-pro-mini-itx-case/
there's only limited space
There's a reason why Apple and others in this form factor uses proprietary boards with custom sizes, so they can cram more stuff into it. AFAIK the original trash can mac pro had inside a triangle construction, where 2 GPUs and the motherboard were put on each of the 3 sides. Then they had custom cooling solutions too.
Only option would be make the case bigger or somehow cram the gpu on the backside of the motherboard with a shielded riser
but nice construction work nonetheless :)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
