Hello, I am going to build my first pc and i need to help out with choosing brand of SSDs and HDDs. Im actually thinking about making it with 2 SSDs and 1 or more HDDs. I thought i could go with one 256GB SSD from Samsung for OS, another 1TB SSD for games and HDDs for storage, but Im a bit confused with the SSD for games because of writes limitations. Will this be fine ? If not I would be pleased if you responded by wise answer.
https://linustechtips.com/topic/961862-i-need-help-with-storage-selection/
You're not constantly rewriting the games over and over, usually you install a game and then it sits there for weeks or months without a single file changing, other than perhaps a small patch here or there. That's actually less traffic in practice on the disk than e.g. the OS itself would generate on the OS-disk. A modern SSD in regular use should last something around 10 years or more, so you have nothing to worry about, anyways.
If you get a good SSD, you won't kill that thing easily. I would highly recommend Samsung's 850/860 EVO SSDs. They're very fast and reliable drives. I have three, none have given me any trouble.
They have ridiculously long lifespans nowadays, so don't worry about it.
As others have noted, SSD's have much longer lifespans now a days, so unless you're constantly writing 100's of GB to the drive every day, I'd get an SSD for both the OS drive and storage if you can afford it. :) Crucial's MX200/300/500 drives are my recommendation for SATA SSD's, as they provide nearly the same performance as Samsung's equivalent SATA based SSD's at a little cost savings, but Samsung's options are just as good if you don't mind spending a few more bucks.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
