Need help choosing the right CPU
Go to solution Solved by LienusLateTips,
Find a i5 2400 or 3470, either can be found for about $30 USD. The 3470 is faster but requires a BIOS update.
I wouldn't recommend a more expensive option: save for a new GPU.
Hello, I am just getting into PC gaming and I used my old system. I have a Intel Celeron Dual Core Intel Celeron G550, It's clocked at 2.6Ghz. Now for graphic I have a MSI Gaming X 1050ti. I'm sure most of you have figured out the reason i'm writing this right now:(. CPU BOTTLENECK:((((( I just want to play 1080p but for some games this isn't even a possibility. With some basic games running as low as 20fps, while the graphic card usage only reaches 15%:(( So I am looking for a new CPU, I don't want to spend too much now as I am just getting into the PC gaming genre. So would you guys/gals have any recommendations?. I'm looking for a CPU which will fit in an LGA1155 Mobo and will not bottleneck my CPU. My budget is around £80 but if that isn't possible tell me what you'd personally do in my senario. Thanks in advance for the help:)  PS- If any are you are curious, I got an ASUS P8H61-MX R2.0 mobo.
https://linustechtips.com/topic/961581-need-help-choosing-the-right-cpu/
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
So if i went for a i5 2400, do you think ill be CPU bottlenecked in most games still? And is the BIOS update a hard thing to do? I am okay with computers but have never attempted to update anything other than a mobo? Also I really appreciate the advice:)
No, it won't be bottlenecked at all.
BIOS update is pretty easy. Here's a old LTT video showing you how to do it. It's released around the same time as your motherboard so it should be valid.
Full Specs
Helios EVO (Main):
Delta - Laptop
Man, I'd love to but it is unfortunately outta my price range:( Student here with only a part time job. Maybe one day:)
Ouch, alright.
What games are you looking to play in particular? The i5 (or even an i3 if that's too much) would be a significant upgrade for that 1050 Ti to stretch its legs a bit.
Bear in mind it may be a short-term solution.  Its expected that next-gen of consoles will bring multi-core gaming finally to the forefront and push PC users to need more cores than we currently do.  Still, probably a few years down the line before it becomes a big problem.
As you are just replacing the CPU its not like you have much choice, and in that price range I strongly believe you will still be bottlenecked depending on what games you play.
Personally I refer to https://www.cpubenchmark.net/mid_range_cpus.html as a guideline for CPU performance.  Its obviously not perfect, but it gives you a pretty good idea how different CPUs compare in raw performance.
Even a 20 pound i3 wouldn't bottleneck it.
Full Specs
Helios EVO (Main):
Delta - Laptop
Depends on the games and if future ones will push more AI, physics, etc.  Some games such as Assassins Creed Origins bottleneck on practically any CPU that isn't high-end.
Also the faster the CPU, the shorter the load times.  I was shocked how much a difference it can actually make.
Wow, Super simple. Never
Yeah, well I think im going to try the I5-3470, The BIOS update thing is super simple. Also watching old LTT videos is super strange. I've never eally watched their older vids, SUper cool. Thanks for the advice:)
I'm only going to be playing games such as GTAV, KF2, Fortnite. Stuff like that. Nothing too serious. Just need something for now to make them playable until i invest in a new system.
I'd be wary as Sandybridge chipsets can have RAM issues with Ivybridge CPUs.
I had to remove a RAM stick to get my own machine to POST when I upgraded it to an i5 3470T from an i3 2120 (done for AES-NI support not speed, before anyone wonders).
5 minutes ago, RileyWeston said:
What do you think of the i5-3330, any better than the ones you recommended to me?
It's between the 3470 and the 2400 in performance I believe. You can pretty much compare these two generations clock for clock as they are nearly the same architecture.
Full Specs
Helios EVO (Main):
Delta - Laptop
I have purchased the i5-3470:) Lets hope its good enough! Thanks for your help guys! I really appreciate it as I wouldn't have had a clue alone. As I don't use this forum much can i mark my post as solved or anything?
The check mark on the bottom of each post.
Full Specs
Helios EVO (Main):
Delta - Laptop
