Currently i bought vega 64 Nitro+, but it is still in the return period, i choose it because i have freesync monitor on 1080p 144hz. However since so many leaks, for a new GPU of Nvidia, i feel uncertain.
My cpu is Ryzen 7 1700. If i wait for a new GPU lets say for 2070 which is to be rumored to be a shy 1080Ti, will i see an improvement compared to my current vega 64?
My uncertainty is that will my cpu bottleneck the 2070?(lets assume it to be shy 1080Ti performance)
is there a benchmark of 1700 with different GPU ? because i want to see how ryzen scaling to different Tier cards
https://linustechtips.com/topic/960853-need-advice-for-gpu/
If you overclock the 1700 it will be fine, especially in 1440 and higher res.
I have the 1700 with a 1080ti and it runs fine.
I only see your reply if you @ me.
https://linustechtips.com/topic/960853-need-advice-for-gpu/#findComment-11650264
I personally don't feel it's worth returning the card because you're able to use Freesync on such a monitor. Especially if your V64 was bought at a good price.
A Ryzen 1700 does encounter a small bottleneck at 1080p 144hz. A decently OCed 1700 (3.85Ghz+) will reduce this bottleneck to negligible levels though.
I'm not even going to try to speculate about the 2070's performance because there have been no legitimate reviews or benchmarks yet (obviously).
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/960853-need-advice-for-gpu/#findComment-11650268
Here in EU the price tax is really high, got it for 500€ but that the usual price equivalence in EU. i am just uncertain if for example i return it and try to buy 1080ti after new gen launch is the price really justify the performance that i get
https://linustechtips.com/topic/960853-need-advice-for-gpu/#findComment-11650297
Do you have a GOOD Freesync monitor, let's say IPS or VA panel? If yes, keep it. If you have cheap TN junk, and if you have the money, return it and go with the RTX 2070... but ultimately you will need to pay far more considering G-Sync monitor prices.
https://linustechtips.com/topic/960853-need-advice-for-gpu/#findComment-11650344
I have VA panel, this it the link
https://www.acer.com/ac/en/GB/content/model/UM.HX1EE.019
https://linustechtips.com/topic/960853-need-advice-for-gpu/#findComment-11650391
