CPU speed decline
3 hours ago, John Love said:Hi aftetr about a week of owning my new computer i5-7400 wiht bas of 3.0 and turbo 3.5 in specs. the speed of it went from 3.45 average on task manager to 3.28 on task manager is there a reason for this and if so is there a way to fix this and if not will it just continue to get worse and worse probably
The base clock is 3ghz of your processor. The "Turbo" 3.5ghz is only activated when the PC needs the extra power to perform tasks. The reason your average clock speed is lower is that it's probably using less CPU resources and is idling more now than it was when you first got it.
When you first got your machine a week ago, things like driver updates and windows update would have run in the background without you noticing eating up a lot of CPU resources, and likely causing your CPU to boost. Now a week later your machine doesn't need to perform those tasks and is spending more time idling, and that's why your CPU is showing lower average clocks.
As long as it's staying above its base clock it really doesn't matter. Providing it doesn't restrict itself due to thermals, the CPU will boost itself up to 3.5Ghz when it is needed.
36 minutes ago, Origami Cactus said:If you use the intel stock cooler it probably slowly fills with dust.
OP said it was a difference noticed within a week of having their new computer. The idea that it has since been clogged up with dust and started to thermal throttle is ridiculous.
