Sure you're going direct to the switch with the WAN connection? You'll need something to perform NAT first, so normally it would go internet > router > switch > everything else.
Do you need it to be managed? Any specific features? Or is it literally just to connect them up together?
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644600
Throwing a recommendation out there, I'm pretty fond of Netgear's ProGear switches. As much as I hate Netgear's consumer stuff, I have used ProGear switches and they run like champs.
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644615
I need to figure out whether my router screws with my connection or whether it's just windows on all 3 PCs being stupid.
Router over WiFi to Android devices works fine.
Router over WiFi or cable to Windows PC, upload is severely crippled but download is fine.
I cant go Internet straight to PC to test.
Anyway, I have been troubleshooting this for a long time with no success, I don't want to go into details now, I just want to figure out whether going switch to PC will fix the upload. If not, I will return the switch.
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644638
Well, if it's just that, then pretty much any non-managed switch from a known brand would be acceptable.
That said, if you can't go direct from the modem/line in to your PC, you almost certainly won't be able to go from modem/line in to the switch then to the PC either.
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644650
a light switch
Seriously though, I use some random TrendNet 8 port gigabit switch and it's been chugging along just great
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644657
Noted.
The strange thing is that it used to work before (Internet to PC).
Now the PC doesn't even detect any ethernet connection if I do that.
No modem. Just RJ45 coming to my apartment trough the wall.
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11644672
Is it an RJ45 cable or a socket?  Have you tried a different cable?
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11645391
You can't be sure its "fine" from just looking, or even if it happens to work to one client and not another.  There have been several people on here recently with a similar issue to yours and I believe one replacing the cable fixed it, another had bent pics in the Ethernet port on their PC.
https://linustechtips.com/topic/960198-need-a-switch/#findComment-11645399
