So I got me a budget case which is a cool master box 3.1 lit
 My old case was just a retail one and I had only one exhaust fan one CPU fan and one power supply exhaust fan and usually the temperature is around 25 to 30 Celsius ideal and 40-45C full load.  And the old case Had a side ventilation for the CPU.
Now the new case it's at 30 Celsius at idle, half load 40-45C at full load it's close to 55 Celsius  and my CPU fan blows it right into the clear plastic window.  Now I'm getting a new CPU cooler tomorrow which is the cool master 212 Evo,  hoping it cools the CPU down more and blows all the hot air into the exhaust fan .  Now the exhaust fan only RPMs up to 1200 in the front of my case can take 2x 120 mm fans what should I get do you help circulate the air probably.  IMG_0561.JPG.c46b757e2ecbebab0ed1ada354d5f562.JPGIMG_0562.JPG.1764e2b5a9d37a952ebd60c62afbcad1.JPGIMG_0563.JPG.805e4b415ad0d05c52d9c7ec5110686a.JPGIMG_0564.JPG.030083d49d4912c4cc091549a6073fb5.JPG
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/959927-new-case-need-help/
Two front fans as intake. Don't know much about that case, but if it's like the masterbox 5 you're going to need to up the quality of the fans and get more fans on top as well. Create the positive air pressure with
Front 2x 140 fans as intake
Top as intake
Rear as exhaust
Best & worst cases for your money in 2018 are:
Best Cases overall
I) Fractal Design Meshify C - Airflow and relatively quiet, best all around case
I) Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I) Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent
I) Fractal Design Meshify C mini (mATX)
I) Corsair 400C - Only use with low end components, no 1080 / TI
I) Phanteks 350X - Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I) Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable for low end builds
The worst cases - Do Not Buy
I) NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I) Coolermaster Masterbox 5
Majority of cases on the market
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11642059
Top as intake
Rear as exhaust
They only take 120 mm fans.  There is no top vent there's a ventilation on the bottom but that's for the PSU The only ventilation is the front now if I take the cover off it will be flowing through that thing like crazy and the times are down but looks ugly
and those intake fans are 2 x 90mm connected to my 4 pin n molex and running full speed and it's loud
Been thinking all this heat is building because of my CPU fan orientation but who knows I'll find out tomorrow once I install the new CPU cooler fan and do some tests
My PC:
My Kids PC:
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11642188
31 minutes ago, vjizzle2384 said:
They only take 120 mm fans.  There is no top vent there's a ventilation on the bottom but that's for the PSU The only ventilation is the front now if I take the cover off it will be flowing through that thing like crazy and the times are down but looks ugly and those intake fans are 2 x 90mm connected to my 4 pin n molex and running full speed and it's loud
It's not your fan orientation, it's a bad case in general. I was hoping a optimal fan configuration would help, but it appears it won't. Most of the time removing the front panel helps a ton which you mention is ugly, but helps.
Doesn't seem like your running high end components either, which usually helps not having them in to help with better heat output and airflow.
What are your current front intake fans? It could be swapping them out for better 120mm fans might help.
Best Cases overall
I) In Win 303
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11642277
 Like I said the fans in front I just all fans that I had laying around and then 90 mm.   They both are running at 3000 RPM's each
what components are you talking about I know my motherboard is old and I'm using DDR2 ram 8GB. I will update my motherboard in a year or two it is never going to be trouble or problems only problem I've had is heat issues with this new case I'm going to see if my buddy can 3-D print me a  Front case with more ventilation
what do you recommend for fans 120 mm  i'll have to get three of them as that's all the fans this case can take.  Or I can have him drill holes(Design a image) in the plastic side window
My PC:
My Kids PC:
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11642372
You could also try modding the panel you currently have for better airflow. that way you know it fits perfectly (making a "snap on" panel can be a bitch if you dont know where the holes line up)
I would personally suggest vents on the angular sides of the panels, Or the middle cut out with the sides remaining. Not both, as that would make the front panel far too flimsy and prone to breaking. Theres a Case Modding and DIY section of the forum who could most likely help with that :)
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11643575
Is a case modding on this site
My PC:
My Kids PC:
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11644494
https://linustechtips.com/main/forum/14-case-modding-and-other-mods/
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11644517
3 hours ago, TVwazhere said:
So just install my new CPU cooler and man it made a difference from my stock.
My ideal stays at 22 to 25C  regular computer usage 30-32C using about 40% of CPU and at 100% CPU temperatures ranging from 45 to 50 Celsius all these test  these test lasted 15 minutes each.
 I remove those two intake fans in the front since they were noisy and loud And also I added a small intake fan in the front.
so I don't think my case is bad I just didn't have a good CPU cooler
What do you guys think
My PC:
My Kids PC:
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11645237
Do you think these would be good to get just for a front intake and this hub to connect to CPU PMW Header with SATA power.  Will this work or burn my MOBO
https://www.amazon.com/gp/aw/d/B078LWNFS9/ref=ox_sc_act_image_1?smid=AFRUWVWO3UJ63&psc=1
HUB
https://www.amazon.com/gp/aw/d/B07CH1958W/ref=ox_sc_act_image_2?smid=A3GO5VFCNOM5I7&psc=1
Please let me know so I know to get it or not thanks a lot
My PC:
My Kids PC:
https://linustechtips.com/topic/959927-new-case-need-help/#findComment-11645619
