:URGENT: PC won't power on
Solved by Zeke_,
5 minutes ago, TheGlenlivet said:If you are 100% sure that the cable from the wall to the PSU has power and all connections are made, then either the PSU has gone bad or the motherboard has.
Oh my god I'm such an idiot.....my power switch and power led were switched around......thanks for the help though lmao
zephirus ·
Posted in Laptops and Pre-Built Systems3 -
5
11
millieath ·
Posted in Troubleshooting5 -
1
