Cheap custom water cooling
Go to solution Solved by 3 Lions,
Just now, Psina said:
If you say so.
But i have a problem. In my country it is the 2x the price on all electronic.
So i resorted to ebay and aliexpres.
Do you have any sugestions for air cooler that have international shiping.
Cryorig H7
I am thinking of water cooling my AMD Fx 8300. I am new to custom water cooling so if i can get some constructive criticism of my part list.
And one more thing how should i set up my loop (where is the best place for the pump/reservoir should it be higher or lower then the radiator or not?).
Radiator: https://www.aliexpress.com/item/-/32866344711.html?spm=a2g0s.13010208.99999999.265.70483c006eVKXD (outside of pc case)
Pump/reservoir: https://www.aliexpress.com/item/SC-300T-12V-DC-ultra-quiet-Water-pump-pump-tank-for-pc-CPU-Liquid-Cooling-computer/32589498875.html?spm=a2g0s.13010208.99999999.272.70483c006eVKXD
Cpu block:https://www.aliexpress.com/item/G1-4-Base-Inner-Channel-PC-Water-Cooling-Block-For-Intel-775-1150-1155-1156-CPU/32846986127.html?spm=a2g0s.13010208.99999999.278.70483c006eVKXD
I have everything else(tubing,fittings).
Thx <3
https://linustechtips.com/topic/959765-cheap-custom-water-cooling/
I would not use that cheap aluminum radiator. Buy something copper.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
I wouldn't risk those cheap parts in my pc build whatsoever. Also that cpu cooler is for intel and not an amd am3 platform
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Just get an air cooler.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
I am thinking on some overclocking maybe to 4.5 4.7.
Yeah an air cooler will do fine for that.
زندگی از چراغ
If you say so.
Cryorig H7
زندگی از چراغ
Just get an aircooler from aliexpress
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
